28 with Black hawks >
28 with Black hawks
28 with Black hawks
Old 11-27-2018 | 06:28 PM
bigboat28's Avatar
Default 28 with Black hawks
Would Black hawks work on a 28?
bigboat28 is offline
Old 12-18-2018 | 09:34 PM
My 28 with extension box needs a drive spacer to prevent blowing out and easier to plane off
Brandon Anderson is offline
Old 12-19-2018 | 05:30 PM
I would think they'd act similar to surface drives and youd loose some of the props ability to carry the bow.
Never thought of this until hearing it from a friend that had, I believe a 27' Pachanga w/surface drives. I think it was a bit faster than w/Bravos but the hull ran more wet.
And yeah if you had raised X dimensions, youd probably struggle to come on plane.
Twin O/B Sonic is offline
Old 12-19-2018 | 06:37 PM
Tinkerer's Avatar
Blackhawk drives work best on a hull that naturally carries the bow or has a built in rocker at the transom.
Tinkerer is offline
Old 12-20-2018 | 08:32 AM
bigboat28's Avatar
Isn't that a Pantera hull. Always thought they were built to try to carry the bow?
Old 01-09-2019 | 04:13 PM
onesickpantera's Avatar
According to Jo the 28 does have some rocker built into it .
onesickpantera is offline
