E85 and Holley EFI >
E85 and Holley EFI
E85 and Holley EFI
Old 12-08-2018 | 07:58 PM
Tinkerer's Avatar
Default E85 and Holley EFI
OK - I am thinking on going to E85
What is the best CR for a 598 CI burning E85 - think I heard 14 to 1
Also I have Holley EFI - The FAST system uses a fuel sensor to sense what fuel is being run.
Can this same sensor be wired into the Holley EFI ?
Tinkerer is offline
Old 12-08-2018 | 08:12 PM
GPM
Supercharged E85 works nice.
GPM is offline
Old 12-08-2018 | 10:08 PM
Tinkerer's Avatar
That was my other thought - Whipple and E85
Tinkerer is offline
Tinkerer's Avatar
With E85 do you still need to run an intercooler?
Tinkerer is offline
Old 12-08-2018 | 11:50 PM
GPM
We do, 15 psi and E85 seems to work well.
GPM is offline
Old 12-09-2018 | 08:02 AM
we race a turbo LS on E85(last 6 years) no IC 25psi, 1500hp awesome stuff, we ck it at the pump before we buy, most of the time its about E87-89, and we dont buy in winter, they put more gas in to aid starting when cold. stuff does not want to start when cold, only neg I've seen
ezstriper is offline
Old 12-09-2018 | 03:30 PM
Tinkerer's Avatar
So IF I go natural aspirated what CR should I run?
They make a tool for testing the fuel.
What about the sensor that they use with the FAST system?
Tinkerer is offline
Old 12-09-2018 | 03:42 PM
sutphen 30 is offline
Old 12-09-2018 | 04:00 PM
Tinkerer's Avatar
IF I was to go to a Whipple what size for a 598?
My engine was designed and built to install an M4 Procharger.
I know that that would be the best choice but they are BUTT UGLY
This same engine produced 1425 HP on Dave Wesseldyke's dyno with the M4.
I have enough room to install the intercooler under the engine and IF I could install the M4 as low as possible and run the pipe up the back of the engine that goes to the carb hat I might be able to do that.
I like the looks of the Whipple but I will be going sequential port EFI.
Tinkerer is offline
Old 12-09-2018 | 04:02 PM
Tinkerer's Avatar
My other thought was to talk to Tom Airhart and go to a turbo charger system.
Tinkerer is offline
