Holley EFI system. I want to use a Dual Sync distributor for SEFI. >
Old 12-09-2018 | 05:08 PM
Default Holley EFI system. I want to use a Dual Sync distributor for SEFI.
Holley EFI system. I want to use a Dual Sync distributor for SEFI. I dont know if these are approved. Is there any other option. I need the dual sync to have cam sensor and crank sensors built in .
cyrus77 is offline
Old 12-09-2018 | 05:57 PM
PM sent
800XCR is offline
Old 12-09-2018 | 06:10 PM
Tinkerer's Avatar
forgive me but what does SEFI stand for.
I am using that distributor for sequential port injection. Holley HP
Tinkerer is offline
Old 12-10-2018 | 12:25 AM
"sequential port injection. Holley HP" Yes that it.
https://www.holley.com/products/fuel...arts/565-207BK
It looks not to be Marine approved.
cyrus77 is offline
Old 12-10-2018 | 06:26 AM
you will gain little if anything going to SEFI, maybe a little cleaner idle...maybe
ezstriper is offline
Old 12-10-2018 | 07:34 AM
When you go sequential you are able to tune each cylinder individually at every RPM.
kvogt is offline
Old 12-10-2018 | 07:38 AM
you may want to look into a hall effect crank trigger on the front of the motor. It is crank mounted and a larger diameter for precise measurement of the crank position.
kvogt is offline
Old 12-10-2018 | 01:19 PM
THen what about the cam sensor needed for sequential?
cyrus77 is offline
Old 12-10-2018 | 02:59 PM
^ then you could use a late model GM distributor for the cam signal (vortec 5.7).....many options
SS496 is offline
Old 12-10-2018 | 03:21 PM
GPM
Started with the Accel dual sync roughly 16 years ago, not the best product but the only one at the time, run the Fast dual sync now for 8 or 10 years, very similar to the MSD / Holley, works great.
GPM is offline
