Efi
Old 12-16-2018 | 06:32 PM
Tinkerer's Avatar
Default Efi
doing some mods to my 598.
I bought the Holley smart coils and was thinking on going with a crank trigger and cam sensor instead of the dual sync distributor.
Are these the right parts
MSD cam sync and oil pump drive P# 85141
will this work with a tall deck?
Holley crank trigger wheel 36-1 tooth P# 556-113
or should I run the 60-2 wheel
Tinkerer is offline
Old 12-16-2018 | 06:55 PM
GPM
eMSD cam sync and oil pump drive P# 85141, comes with a slip collar.rface with most afterHolley EFI systems and can easily interface with most aftermarket EFI systems. Chevrolet Model Features Melonized Gear and Adjustable Slip Collar for Deck Height Variations.market EFI systems. Chevrolet Model Features Melonized Gear and Adjustable Slip Collar for Deck Height Variations.
GPM is offline
Old 12-16-2018 | 07:15 PM
Tinkerer's Avatar
Great
What about the wheel?
Tinkerer is offline
Old 12-17-2018 | 07:51 AM
I run the 60-2 it supposedly gives slightly better idle with more precise crank position. Some drag race guys have had issues at high rpm with it though, my setup has been rock solid to 6400 rpms.
kvogt is offline
Old 12-17-2018 | 09:51 AM
Either wheel will work fine at marine BBC engine speeds.
SS496 is offline
Old 12-17-2018 | 12:07 PM
ATI makes some built in trigger wheels..
ATI - Crank Trigger Shells
Would this be a better option so pulleys belts and such don`t have to realigned due to the extra wheel?
ICDEDPPL is offline
Old 12-17-2018 | 12:27 PM
BUP
MSD / Holley has them as well.
The higher the X the better the resolution. for a jist
BUP is offline
Old 12-17-2018 | 02:59 PM
pretty slick!
getrdunn is offline
Old 12-17-2018 | 03:42 PM
GPM
I always liked to keep it simple, dual sync worked fine for me.
GPM is offline
Old 12-17-2018 | 09:20 PM
Originally Posted by getrdunn
pretty slick!
I don`t really want to move and realign all my accessories to fit a flying magnet in there
Figured this would be a nice option?
Alex Haxby pointed out he likes to use a dual sync with a billet cap, no need for a seperate crank sensor.. seems like another option.
ICDEDPPL is offline
