Best set up for block drains >
Old 12-18-2018 | 12:24 AM
Default Best set up for block drains
I like to drain the block for the winter, but the plugs are a mofo to get to with all of the hoses around that area. I bought the plugs with the wings on it but they didn’t help matters any. Has anyone put extension hoses on them to a port valve of some sort? Surely there’s a decent system of some sort?
Baja Rooster is offline
Old 12-18-2018 | 04:42 AM
I'd tap the drain plug holes out to the next size and then run the extension hose.then you can use welding wire to open up any blockage w/ ease.
sutphen 30 is offline
Old 12-18-2018 | 08:10 AM
I made some tools for the shop to help with the Mercruiser blue plastic wingnut drain plugs, I found them a real PITA. we have a few hand held ones and one on a flexible shaft. We always use dialectic on the thread when we reinstall them which helps for the next year.
Camalot is offline
Old 12-18-2018 | 08:46 AM
J-Bonz's Avatar
I installed these on our old Top Gun. It greatly cut down winterizing time!! 3 hours of playing twister to ~15 minutes for both engines. I was worried about them falling due to vibration but never observed an issue...
https://www.directmaterial.com/stain...0-psi-wog.html
J-Bonz is offline
Old 12-18-2018 | 09:19 AM
F-2 Speedy's Avatar
Those are pretty cool JB ^^^^^^ how long are they ??
F-2 Speedy is offline
Old 12-18-2018 | 09:39 AM
J-bonz
did you leave them as they were after you installed the valves or did you add extensions? I like the idea. Should’ve done it when the motors were out.
Smoke eater is offline
Old 12-18-2018 | 09:49 AM
BUP
I have installed prob at least 700 of these and always have about 40 on hand if this helps whomever. Very easy to install.
BUP is offline
Old 12-18-2018 | 10:02 AM
Do these thread into the fitting in place of the blue plugs, or does the brass fitting need removed from block and these thread into the block?
Cory H is offline
Old 12-18-2018 | 10:06 AM
F-2 Speedy's Avatar
They install directly in the block,
Edit: they appear to be about 1.5 inches long, so about the same length as the brass adapter and blue plug together
Old 12-18-2018 | 10:08 AM
When I refresh motors in a couple years, these will be added. No way I can do it with engines in boat.
Cory H is offline
