Scarab panther questions >
Old 12-27-2018 | 05:03 PM
RHudson1's Avatar
Default Scarab panther questions
I’m a recent owner of a 1988 Panther , I am replacing the power this winter. Would tall deck motors fit without moving the motor mounts wider , and of course the problems down stream that that would create?
I am pulling the factory 330 hp 454 motors that have 1430 hrs on them. I need to work on the stringers where the motor mounts are I have found the traditional cracks. I have drilled the transom, and I get fresh pine shavings. Lucky as hell I bought the boat at a deal and took the chance!
Any other suggestions to do while I have the motors out.
RHudson1 is offline
Old 12-27-2018 | 06:33 PM
jeff32's Avatar
Fresh bilge paint! Looks nicer ans more easy to clean and keep clean!
jeff32 is offline
Old 12-27-2018 | 09:37 PM
Rookie's Avatar
I wouldn't do tall decks. Barely any room if you went to aftermarket exhaust. Here is a link to my Panther project over the years. Maybe it might give you a few ideas while the engines are out.
https://www.offshoreonly.com/forums/...-progress.html
Rookie is offline
