Head gasket thickness
Looking for correct head gasket for my stock carb’d vortec 5.7 with gm 395 cam. I’ve read lots of post with people saying .015 to.038 compressed thickness.
I order the felpro 1094 before doing any research 🙄 now I’m having second thoughts.
In my opinion you should not use the 1094. It is a steel shim gasket and if you have the stock Vortec heads in my opinion they are too flimsy to seal real good with those.
Truthfully all you need is the stock replacement Mercruiser or FelPro marine gasket. They should be .038 thick.
thanks for the imput. this engine used a .020 head gasket.
