Which Rinda/Diacom connector for the indmar SN? >
Old 01-02-2019 | 08:46 PM
Default Which Rinda/Diacom connector for the indmar SN?
Hi- need to know what cable I need for this model? MEFI4 or 5? I wd think 4but it has the silver ECM with 3 plugs attached-
7INDM05.7CAT 5.7L
MODEL: 057676
ENGINE: 129399
MFG DATE: 06/28/2006
CamaroMan is offline
Old 01-03-2019 | 12:40 AM
BUP
MEFI 4 s all of those were black cased and 2 front J connectors. Silver was MEFI V for those years and E Controls was a tad later depending on engine serial numbers. . Indmar only used Mefi and E controls. I take it your engine is Emission controled with catalyst and O 2 sensor exhaust ?? would that be correct
MEFI V thru VII are silver cased. MEFI 1 thru 4 all are black cased
BUP is offline
Old 01-03-2019 | 10:11 AM
bup thanks - yes i believe it has the CAT. I see rinda lists the 94029 connection for CAT systems- so do I need the 9027 or 94029?
Indmar:
• 1992 - Up EFI engines:
1992 - 2007 (GM MEFI-1 thru MEFI-4) Adapter #94005
2007-2008 (GM MEFI-5) Adapter #94027 (will NOT work with PRO)
2008 - Up (CAN Network adapter for all catalyst equipped engines, also used on many manufacturer's 2008-up engines) Adapter #94029
2008-Up (Indmar ECM) Adapter #94027 (will NOT work with PRO)
Old 01-07-2019 | 03:14 PM
BUP
the 94029 adapter is for CAN and yes all the CAT engines have this as well.
I do have one extra brand new CAN adapter rinda / Diacom 94029 I can sell for $ 200
This cable thru Rinda / Diacom is $249 plus shipping and is listed on their website. .
Let me know ASAP before I sell it. thanks
BUP is offline
Old 01-07-2019 | 08:53 PM
what is CAN? sorry- canadian model or the CAN system on the boat? And can i use the NON CAT cable on a cat system, will it make a difference? Sorry-still trying to get to grips with all the acronyms..
Old 01-07-2019 | 10:09 PM
BUP
CAN systems - marine apps.
CAN aka CAN Bus = Controller Area Network
NMEA 2000
BUP is offline
Old 08-10-2020 | 05:20 PM
HI
Do you still have the extra 94029 adapter?
z3cta is offline
Old 08-10-2020 | 05:21 PM
HI
z3cta is offline
