Tire pressure monitoring systems >
Old 01-11-2019 | 11:53 AM
C_Spray's Avatar
Diamond Member #001
Default Tire pressure monitoring systems
Does anyone have any feedback on the current systems?
I had a system a few years back, but sold it with the boat. My trailer is a tri-axle, and it's about 45' from the wheels to the dash. While the screw-on senders are easy to install, I'm concerned about the stress on valve stems and water intrusion, so maybe the internal-mount systems make more sense, especially around salt water.
C_Spray is offline
Old 01-11-2019 | 12:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I bought this in September for my toy/racecar hauler; and LOVE it.
TPMS-APP-6.html
It comes with a repeater, and it works great.
If you don't have solid metal valve stems, you will have to change out to such, but that's not a big deal. With a portable bead breaker, you could DIY with the wheels still on the trailer (one at a time).
Sydwayz is offline
Old 01-13-2019 | 12:15 PM
C_Spray's Avatar
Diamond Member #001
Thanks, Brian. I assume that the sending units are sealed, so dunking them at the ramp is not an issue?
C_Spray is offline
Old 01-16-2019 | 09:53 AM
I just bought this for my 450. Hope to get it installed soon.
https://www.pressurepro.us/product-pulse-fx.html
PremierPOWER is offline
Old 01-16-2019 | 02:34 PM
C_Spray's Avatar
Diamond Member #001
Looks similar to the system Sydways has, but everything stays attached to the trailer?
C_Spray is offline
Old 01-17-2019 | 10:39 AM
This allows me to see all tires and temperatures at the same time and looks better IMO. The only thing that stays on the trailer are the tire pressure sensors. The receiver wires into the truck. You can name different trailers and have them all programmed and it recognizes each trailer differently.
Old 01-17-2019 | 10:57 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I’m pretty sure it’s good for that. You would have to confirm. I had to install the batteries and O-rings. And they sell a service kit for such which makes me think they are good for dunking. The have it on my Toy Hauler.
Sydwayz is offline
