Rebuilding stringers, floor, and transom >
Old 01-20-2019 | 11:18 AM
LostinBoston's Avatar
Default Rebuilding stringers, floor, and transom
I’m considering a project boat. It will at least need new stringers and floor, possibly transom. Who has done this before and has some words of wisdom. What is a realistic cost and level of effort for a 23’ boat? I’m thinking Coosa for the transom, posssivle floor, and seacast or Nida for stringers. Any other materials to look at? Thanks for your suggestions.
LostinBoston is offline
Old 01-20-2019 | 12:30 PM
Lots of threads in the Fiberglass and Paint Section. That's a whole lotta work for a 23' boat.
Griff is offline
Old 01-20-2019 | 07:06 PM
Unless I had a diamond in the rough priceless boat I'd find another project boat. Trust me....
getrdunn is offline
Old 01-20-2019 | 08:49 PM
You do not want to do a coosa transom.
phragle is offline
Old 01-21-2019 | 11:27 AM
What material would you recommend and why?
Old 01-21-2019 | 11:54 AM
Knot 4 Me's Avatar
Plywood.
Knot 4 Me is offline
Old 01-21-2019 | 02:07 PM
Find a 23' boat that doesn't need so much work. It will be cheaper than your project in the long run. I did my 28' hull for two reasons. It is a Cigarette Racing Team hull, and I am crazy!
ren3 is offline
Old 01-21-2019 | 02:14 PM
why? Seems that’s what most builders use now
Crude Intentions is offline
Old 01-21-2019 | 06:16 PM
3 layers of 1/2" marine ply laminated together. Coosa is great stuff when used in conjunction with its properties. As a stringer or bulkhead its great (with the exception of the motor mount area on the stringers)
For a transom, it does not like compression and shear.
phragle is offline
Old 01-22-2019 | 11:32 AM
wow,,,i did not do the glass work , but gutted my engine compartment of everything
u will have to reset your motor mounts
need alignment tool for that
lots of work...
i post a thread
38 scarab rebuild
flashgordon is offline
