Marine Machine Ram Rebuilding >
Old 01-26-2019 | 07:56 PM
Default Marine Machine Ram Rebuilding
Can anyone point me in the direction of someone good that can rebuild one of my Marine Machine steering rams?
endeavour32 is offline
Old 01-27-2019 | 09:02 AM
I would take it apart and look at the o-rings and the bore.if its scored at all,take it to a hydraulic shop,they rebuild these rams all the time.
sutphen 30 is offline
Old 01-27-2019 | 09:38 AM
Rookie's Avatar
I believe mine were marine machine.
Steering Rams Rebuild
Rookie is offline
Old 01-27-2019 | 09:45 AM
Thanks! Yes, yours look very similar to mine, other than I don't have treaded, adjustable ends on mine. Where those off your AT?
I'm going to look up to see where a local hydaulic shop is, looks simple enough to repair. Mine have a leak, most likely in the wiper. I just discovered a wet area under one of my rams. I took my finger and wiped it along the rod, and sure enough, fluid.
Old 01-27-2019 | 10:09 AM
TomFTM's Avatar
Take it apart , most of the seals and o rings u can get from msc or McMaster Carr u will have to measure them .
TomFTM is offline
Old 01-27-2019 | 11:21 AM
bblythe's Avatar
I have shaft material for them . I have machined a number of them for customers
bblythe is offline
Old 01-27-2019 | 11:59 AM
Rookie's Avatar
Those were from the system I pieced together for my Panther. My AT has Mayfair which are the same rams. I spoke with MM to get another cylinder barrel after I blew the cap off and stripped the threads.
MM did tell me that the caps might be loctited on so do not crush the barrel trying to remove the caps. Add a little heat and they should come off easy.
Rookie is offline
