Latham External Hydraulic Steering for Bravo One >
Old 02-07-2019 | 06:56 AM
Default Latham External Hydraulic Steering for Bravo One
Ram, drive and transom mounts only.
Everything you need for the transom side hardware.
No leaks, E.C., easy clean up to pass as new.
$600. plus the ride and I'll throw in a drive shower.
Thx, Gary
937-571-1239
Twin O/B Sonic is offline
Old 02-07-2019 | 07:22 AM
Sick Stinger's Avatar
Brotherhood #1
Great buy for some one who is looking to do add on.
Sick Stinger is offline
Old 02-07-2019 | 11:09 AM
To those asking:
This would be part of a performance upgrade for any single, Bravo powered, OEM mehanically steered boat.
Youd remove your factory steering/helm from the dash and the cable running from it to the tiller arm in the bilge, behind the motor.
That style steering has a dozen places to pick up slop between drive and wheel.
Grab the drive and see how much side to side you have.
Now imagine the drive at speed, particularly on a vee bottom where you’re trying to balance it on the pad/vee.
Near impossible w/that set up.
W/this style, you mount the hydraulic ram between the outside of the transom and the drive itself.
Now try the same test.
The drive won’t move.
To complete the package you’d need a Capalano helm (e-bay), two hydraulic hoses from dash to bulkhead connectors on inside of transom (Seatstar hoses to length or custom made at any industrial supply) and lastly, two short, pigtail hoses from bulkhead connectors on outside of transom to ports on ram.
Bleed the system and you’re done.
Youll never look back.
As a bonus, it looks great.
Clear as mud?
Old 02-07-2019 | 11:47 AM
Default latham steering
I am putting hyd steering on my 1969 donzi. I have a alpha1 outdrive but can find a wing plate for it. is this single ram or duel rams?
blinds5.2 is offline
Old 02-15-2019 | 02:59 PM
Sold.
