HP upgrades for 280TRS x2 >
Old 03-04-2019 | 06:59 PM
EDT
Default HP upgrades for 280TRS x2
Im lookin to add some power to my Mirage 9mss. (heads , intake and cams). The boat is 5200#'s
EDT is offline
Old 03-04-2019 | 09:23 PM
Rookie's Avatar
I ran between 500-600HP through TRS's for years 30' Scarab Panther.
Rookie is offline
Old 03-06-2019 | 01:56 PM
EDT
I guess I should have ask what heads and cams would be recommended. These motors being 4 bolt mains and 6qt pans I am ok with turning 5500rpm
EDT is offline
Old 03-06-2019 | 02:12 PM
A good set of large ovals and rpm air gap intake but someone way smarter than me will have to recommend a cam.
TylerBurich is offline
Old 03-06-2019 | 03:27 PM
No shortage of love for the Crane 741 cam. A bigger pan seems like a good idea though.
Baja Rooster is offline
Old 03-06-2019 | 04:03 PM
EDT
280trs mercruises are 350 cid SBC based on a 1972 LT1
EDT is offline
Old 03-08-2019 | 09:04 AM
vortec heads (will require a little machine work), comp cams xm270HR, edelbrock intake, holley marine carb.
I know people have reported good results running the lt4 hotcam as well.
What exhaust does your boat have?
Russ
highplainsdrifter is offline
Old 03-08-2019 | 11:51 AM
EDT
Thank you for your reply Russ.I was wanting to stay with 23deg. heads , I was thinking something with 64cc chambers to get me to a little over 10-1 and 200cc intake runners. As for the cams, a lil hotter the 278 and a airgap dual plane. They have the stock iron logs with the risers changed to go straight out the transom (3"). Im sure that will be my limiter.
EDT is offline
Old 03-08-2019 | 12:17 PM
My apologies I assumed this was a lower power BBC. Hard to beat vortec heads when upgrading older SBC's
Old 03-08-2019 | 03:43 PM
The vortec heads are 23 degree heads and they also have 64cc chambers. They do not have 200cc intake runners, but I think that may be a little overkill for en engine running 5500RPM or lower.
Of course Edelbrock and AFR make nice heads that would work well. When I put my small block together, I went with the Edelbrock heads.
