Help! unable to maintain power
Last run of the year last summer and I started having trouble w starboard engine. Starts fine. Idles fine. Run both engines upto 2800 rpm and goes on plane. Go up to 300 rpms and motor stutters for a second and drops to 2500 rpms. comes back up to 3000 then drops to 2500. If I throttle more and go to 3500 the lag gets worse and still drops to about 2500 and takes longer to hit again and get back upto 3500. If I go w more throttle I could get it to stahl. When I run it on the hose I can tell anything is wrong. I replaced the cap and rotor and coil becasue they were 8 years old and did the other motor earlier in the year because the coil died. Checked fuel filter and it was totally clean. Swapped fuel pumps. I did those things but was never able to get on the water again to see if anything happened. Its mid winter and thought I would see what the wonderful world of OSO would have to say. Btw It ran fine the day before. All gauges reading normal
Both post above I believe on the right track including a little more info on the engines. What year and what engines and ignition and efi or carb. If t-bolt ign did you swap out distributors and modules. Could be something simple and could be time figure out how your going to spend your tax return.
More info.... Alao hours on engines sense new or rebuild. Could even be lifter failure. Many possibilities.
I had 2 similar issues.
1. My secondaries got contamination in them and boat would run great until the secondaries were opened.
2. Ground wire loose/broke (inside shrouding) on my ignition box.
