Fuel Filter - low restriction >
Old 03-15-2019 | 08:01 AM
Default Fuel Filter - low restriction
Hi guys,
Looking to upgrade 454s soon to blowers, larger fuel lines and pickups but also replacing fuel filters - any recommendations? Would like to get the larger/longer ones as I do get some moisture in fuel tanks (humid Florida and old marine gas stations) and could use the extra protection.
What are you running on smaller blower motors?
Swamplizard is offline
Old 03-15-2019 | 02:43 PM
https://www.fstperformance.com/rpm500
TxHawk is offline
Old 03-16-2019 | 12:18 PM
Lots of options https://www.cpperformance.com/c-494-...ers-heads.aspx
Griff is offline
Old 03-24-2019 | 11:20 AM
Originally Posted by TxHawk
Was going to use with the OE base; however, the FST explicitly says not to. In comparing OE filter base dimensions with the FST's there are slight variances. Looks like one will have to go with the entire remote FST kit to use their filters.
Tractionless is offline
Old 03-24-2019 | 11:34 AM
BUP
stock mounts -- Racor or the Large Sierra.
BUP is offline
Old 03-24-2019 | 11:36 AM
I Run These With Wix 44318 Seperators on my 1200's
https://teaguecustommarine.com/em001...ht-pewter.html
bigfarmer is offline
Old 03-24-2019 | 12:05 PM
boatfreak's Avatar
Same here
boatfreak is offline
Old 03-24-2019 | 12:15 PM
Rookie's Avatar
A little discussion on the topic.
Best flowing fuel filter/water separator
Stock Fuel/Water separator hp limit
Rookie is offline
Old 03-24-2019 | 05:21 PM
We always ran just the cheap permacool mounts from jegs. I want to say 1/2” and they were 35 bucks or so.
tmmii is offline
