it is an old boat and you think it’s dry, check again. >
it is an old boat and you think it?s dry, check again.
Old 03-18-2019 | 08:00 AM
RHudson1's Avatar
Default it is an old boat and you think it’s dry, check again.
Port putter most exhaust port Scarab Panther
Transome on a Scarab Panther . You can see the water migration from the port exhaust
Center stringer where it attaches to the transom
RHudson1 is offline
Old 03-19-2019 | 06:55 PM
Especially if it is a 30 year old Wellcraft! These things didn't stand a chance with all the exposed wood on the stringers. I thought I bought one with a solid hull, but it gets worse the more I dig. Are you removing the cockpit floor as well?
Springman is offline
Old 03-19-2019 | 07:01 PM
RHudson1's Avatar
RHudson1 is offline
Old 03-19-2019 | 08:29 PM
hblair's Avatar
Preach it brother.
hblair is offline
Old 03-20-2019 | 07:45 PM
Tinkerer's Avatar
While you have it that far apart you might consider raising the drive height at least 2 inches. real cheap to do right now.
Tinkerer is offline
Old 03-20-2019 | 09:43 PM
RHudson1's Avatar
Default Drive height
I have thought about doing that, weighing raising the center of gravity v.s. The cost of short lowers to gain a little speed. Those that have raised the drives, what were the performance increases , was there an adverse affect on the center of gravity?
RHudson1 is offline
Old 03-21-2019 | 05:25 PM
Rookie's Avatar
My '86 Panther is dryer than my newer 2000, so check them all. I guess the real question is how wet and what is an acceptable moisture reading. Had a friend that called Formula about a boat he was to purchase, and I believe they said anything above 30% they would start worrying about it. I thought that was a little high.
Rookie is offline
Old 03-21-2019 | 07:16 PM
rak rua's Avatar
Love these threads and admire you guys with the skills and dedication who take on the work.
Thanks for posting....... keep us updated.....
RR
rak rua is offline
Old 03-21-2019 | 08:09 PM
RHudson1's Avatar
As I cut into my transome at the bottom and I to the center stringer, water came running out. I would assume my moisture content wins.
The smaller stringers locates on each side on the center , the wood is missing, just some left over strands of what I assume to be cellulose.
I have the wood wood cut and fitted for the transom. Wrestling 3/4 ply into the boat and back out a few times was fun. I then coated them with epoxy with a slow hardener to let it soak in.
RHudson1 is offline
Old 03-23-2019 | 02:12 PM
I did my 89 Panther. Transom, stringers up to the helm. Lot of work, but came out great!!
TomR is offline
