mild build 454 >
mild build 454
mild build 454
Old 03-22-2019 | 08:14 AM
F-2 Speedy's Avatar
Default mild build 454
I'm building a pair of 454 mag engines for a friend, he wants to hot rod it a little, Ive not messed with these before so all info is appreciated
They are fresh from the engine shop with stock short blocks assembled, forged internals, fresh 088 heads but not installed. He has 502 MPI intakes and ecms for these builds. What cam would work good with just a spring upgrade.........he's also thinking of low boost small blowers, these will be going in a 29 Outlaw with B 1's....he thinks there gen 6 blocks, going to pick them up Saturday
Does this sound like a thousand other threads..........lol
F-2 Speedy is online now
Old 03-22-2019 | 01:15 PM
Is he upgrading exhaust??
Griff is offline
Old 03-22-2019 | 01:33 PM
F-2 Speedy's Avatar
It will new for the application he picks
Old 03-22-2019 | 04:45 PM
for a mild build,,651 cam and a 5 liter whipple.
sutphen 30 is offline
Old 03-22-2019 | 05:03 PM
F-2 Speedy's Avatar
and two new bravo's......
Old 03-22-2019 | 05:28 PM
way more than 2.
Old 03-23-2019 | 08:15 AM
On a serious note,I'd be inclined to use an HP500efi cam,,that would juice it up some for you,will need an ecu reprogramming.
Old 03-23-2019 | 12:31 PM
All very close in specs and would work well.
Standard Crane 731 https://www.summitracing.com/parts/crn-168731/overview/make/chevrolet
731 on a 114 lob sep https://www.summitracing.com/parts/c...make/chevrolet
I think 500efi cam https://www.summitracing.com/parts/c...make/chevrolet
Griff is offline
Old 03-23-2019 | 01:39 PM
Rookie's Avatar
I'm putting together 2 Merc 420's currently and the only thing I'm changing are the cams and going to hydraulic roller lifters. I'm using HP500EFI cams, Crane 169621. Great minds think alike. It looks like a great combination.
Rookie is offline
Old 03-23-2019 | 04:10 PM
F-2 Speedy's Avatar
Thanks guys just got back from Wichita with the engines, keep the ideas coming....
