889275T Fuel Pump Assembly >
Old 03-24-2019 | 08:26 PM
Rookie's Avatar
Default 889275T Fuel Pump Assembly
Is this just a lift pump for an electric fuel pump? Or is it regulated to run a carburetor off of? I show's it will run off a sea pump from 525EFI-799SCI. Need a sea pump fuel pump.
https://www.mercruiserparts.com/889275t-pump-assy-fuel
Rookie is offline
Old 03-25-2019 | 07:14 AM
Would need to know what motor, but
You want 861677T
https://www.mercruiserparts.com/861677t-pump-assy-fuel
or Airtex 60932 which makes the pump for Merc
Amazon Amazon
AllDodge is offline
Old 03-25-2019 | 12:03 PM
BUP
Merc has these pumps done over in Korea if I recall correctly. Its fits the 525 hp and some other models as a boost pump to feed the high pressure electric fuel pump.
BUP is offline
Old 03-25-2019 | 12:09 PM
You want 861677T
https://www.amazon.com/Airtex-60932-.../dp/B002HTYRD8
is the airtex a direct replacement for the merc. Bolt and go?
Crude Intentions is offline
Old 03-25-2019 | 12:22 PM
I still have the 130gph Holley pump mated to the factory top for a sea pump if you’re interested.
Quick Fuel 850m and various mech pumps.
Baja Rooster is offline
Old 03-25-2019 | 03:47 PM
Yes, have one on my Rinker (carb) and use to use one on my Formula (502 MPI VST) prior to the repower (509 MEFI3). Bolt and go
AllDodge is offline
Old 03-25-2019 | 07:02 PM
Rookie's Avatar
You want 861677T
The Merc pump is an Airtex? The reviews on the Airtex are hit and miss. I believe mostly due to the rotation of the outlet. I believe it can be clocked differently by unbolting.
The engines are NA 502's Will this pump support 600HP NA?
Rookie is offline
Old 03-25-2019 | 07:04 PM
I’m running the stock merc pumps with 570hp carb engines to 6k rpm with no issues.
Old 03-25-2019 | 07:13 PM
F-2 Speedy's Avatar
Ive got a pair of sea pumps if you need them
F-2 Speedy is offline
Old 03-25-2019 | 07:23 PM
As a non-expert in the design of the pumps, I'll say they pump the same amount as the Merc OEM. So if the OEM work, then they should also. Normally these pumps will pump more fuel then the motor will consume
I'm running a Gen 2 cool fuel (530hp) without a mechanical pump in front and have no issue, and also the pump moves more fuel then my motor will use
AllDodge is offline
