Stress cracks or more serious >
Old 03-30-2019 | 06:02 PM
Default Stress cracks or more serious
I looked at a 27 fever today that had what appeared to be cracks/stress cracks on transom where hydraulic sterring attached as well as cracks on hull under motor. Should I be concerned?
Walter Sobchak is offline
Old 03-30-2019 | 09:56 PM
Tinkerer's Avatar
The transom is most likely very wet and will have to be replaced. I have never seen stress cracks on a healthy transom.
Tinkerer is offline
Old 03-31-2019 | 04:34 PM
I have seen cracks like that in gelcote that is non structural and structural. Poor quality gel formulation. Common in older boats . Gelcote will flex without cracking to a degree.
oconnor marine is offline
Old 03-31-2019 | 05:21 PM
This photo is the hull. I don’t have a photo of the transom, but there’s cracks right at hydraulic steering attachments as well.
Old 04-01-2019 | 12:52 PM
I'm not a fiberglass expert, but yeah I'd be concerned enough to keep looking for something else.
TexomaPowerboater is offline
Old 04-01-2019 | 03:48 PM
That would scare me away too.
thirdchildhood is offline
Old 04-01-2019 | 05:24 PM
Thank you for responding. It’s unfortunate because the boat is beautiful. Search continues
Old 04-03-2019 | 05:14 PM
If the boat is otherwise one you would consider then take things one more step and have a moisture test done. Then base how you proceed from there on the results. Might even ask seller to cover the cost or share in the cost in some manner.
RaggedEdge is offline
