Hp6a filter too long
Old 04-05-2019 | 12:36 PM
Default Hp6a filter too long
does anyone have a cross reference to shorter filter ???
phragle is offline
Old 04-05-2019 | 01:03 PM
First problem is that it's a Fram..lol.
Drock78 is offline
Old 04-05-2019 | 01:48 PM
SB
Maybe Wix 57521 ?????
????? means i quickly looked this up. It's your motor, so double/triple check.
HP6A specs/dimensions : FRAM HIGH PERFORMANCE High Performance Spin-on Oil Filter HP6A FRAM
Wix filter look up via specs/dimensions: Catalogs
SB is offline
Old 04-05-2019 | 06:20 PM
Rob, I have some nice horizontal remote mounts I would sell you, then length would not be an issue. Has the nice bracket with engine lift points. Let me know if you're interested.
frickstyle is offline
Old 04-05-2019 | 07:32 PM
Now that its in the boat, I think if I trim the spacers holding the bracket off the head a bit, it will fit.......
phragle is offline
Old 04-08-2019 | 07:52 AM
Dean Ferry's Avatar
Veteran: Air Force
P,
I have the same issue on the Talon's 572, I have to run the Merc Racing filter 35-88112K01....
Hope that helps...
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 04-09-2019 | 09:29 AM
Bu then what, pull the engine to change the oil???...
Old 04-09-2019 | 09:56 AM
F-2 Speedy's Avatar
Is there a long filter with the anti drain back provision ??
F-2 Speedy is offline
Old 04-09-2019 | 10:19 AM
Then I should be able to get filters on and off easily.
phragle is offline
Old 04-11-2019 | 05:56 PM
Spent 5 minutes on the lathe and made shorter spacers... now it not only fi
ts, but also easily goes on and off....
phragle is offline
