500 efi.  Power steering pump >
Old 04-07-2019 | 11:50 AM
Default 500 efi. Power steering pump
Who makes the power steering pump for mercury on a 500 EFI the type with the remote reservoir? Is that a mercury only part proprietary to mercury or is it a GM pump used on a big block Chevy and some application
Velocity Tom is offline
Old 04-07-2019 | 01:04 PM
Could be wrong, but always thought it was just a GM pump, the reservoir is usually part of the hydraulic steering system.
RaggedEdge is offline
Old 04-08-2019 | 05:18 AM
I just went through this!!! It's the same pump GM used on the 1981 thru 85 Cadillac Seville 4.1L..... They're all over Ebay much cheaper than Mercury's $550 price tag.
ccrder1 is offline
Old 04-08-2019 | 07:35 AM
F-2 Speedy's Avatar
Are the internals the same, valve and stuff ?? part #
F-2 Speedy is offline
Old 04-08-2019 | 08:14 AM
Everything is the same... Just need the pressure relief valve out of the original pump. Mercury steering systems run at a lower pressure than automotive. The pump I bought on ebay was a reman... A-1 Cardone #88652YN. You will need a pulley install/removal tool to change out the pulley hub. I ended up having to buy a new hub, couldn't get the old one off. Mercruiser hub #47530
ccrder1 is offline
Old 04-08-2019 | 08:50 AM
SB
Quickly checking the net,
The AcDelco one is a tad cheaper, as a heads up:
ACDELCO 36P0279
https://www.rockauto.com/en/parts/ac...ring+pump,7380
Amazon Amazon
SB is offline
Old 04-08-2019 | 09:54 AM
F-2 Speedy's Avatar
ACDELCO 36P0279
https://www.amazon.com/ACDelco-36P02.../dp/B00QXVLS88
So do ya role the dice and go reman,,,,,,,,,,,,,Im thinking buy new ??
Edit: looks like their all reman.
Old 04-08-2019 | 03:57 PM
I called Cardone today and talk to a tech he said it may look the same but the flow rate and the pressure may be different. Where is the Pressure valve located on the backside where the hose comes in
Old 04-08-2019 | 04:18 PM
The pressure relief valve is located behind the pressure hose fitting
ccrder1 is offline
Old 04-08-2019 | 05:43 PM
WTF,might have been a little off in the prior post here, might be again, but I might have a Merc PS pump kicking around from some years back. Give me a few days, let me look thru some chit, might have a fix for your problem.
I'm guessing that most any Merc PS pump is very close to the same? Subtle differences, but close?
