Bleed ITS steering system >
Old 04-07-2019 | 08:57 PM
Default Bleed ITS steering system
Installed rebuilt engine a few months ago. I am having trouble getting the air out of the system. It is the mercury ITS system. The only thing we have not tried is to bleed the system with the engine running, I cannot find anything about how to do this. Should I try to bleed it with the engine running, if so how should I go about doing that?
Lil Mick is offline
Old 04-07-2019 | 10:07 PM
14 apache's Avatar
Fill power steering pump start motor turn one direction shut off engine fill pump again do the other direction repeat till leavel is Steady let it sit for a bit small bubbles will get bigger. If you have someone to add fluid might help try not to run it out when you start proses.
14 apache is offline
Old 04-08-2019 | 07:50 AM
F-2 Speedy's Avatar
or you can pull the belt from the ps pump and spin it with a drill
F-2 Speedy is offline
Old 04-08-2019 | 11:17 AM
service manual bleeds it and say is bold DO NOT START ENGINES fyi.... whats your email? I can send you the manual I have it pdf.
30outlaw is offline
Old 04-08-2019 | 04:14 PM
14 apache's Avatar
Can you post how this is done?
Old 04-08-2019 | 04:22 PM
14 apache's Avatar
Always liked this the best watch fluid and don't run out.
Old 04-08-2019 | 04:41 PM
F-2 Speedy's Avatar
yep, just have someone turning the wheel lock to lock while spinning and filling the pump, Brad Smith showed me this yrs ago.
Old 04-08-2019 | 06:09 PM
sent you a PM with e mail.
Lil Mick is offline
Old 04-08-2019 | 08:57 PM
Just some clarification I should have put in the initial post. We did the initial bleeding without running the engine when it was connected. Once we ran the motor it seems to still have air trapped that will not work its way out. The system also has Automatic transmission fluid in it should I change it out for power steering fluid? That is what was in it before the motor swap. What is happening now is the fluid is foaming due to the excess air and overflowing the reservoir when running the engine.
Lil Mick is offline
Old 04-08-2019 | 09:06 PM
14 apache's Avatar
does it have remote reservoir ?
