Go Back  Offshoreonly.com > Owners Forum > Hustler
How well does your Depthfiner work shooting  thru hull,puck >
Old 05-04-2019 | 11:01 AM
Strip Poker 388's Avatar
Rob
Question How well does your Depthfiner work shooting thru hull,puck
Its on my 388 Hustler. Im figuring its the same on most other Hustlers. Mine has never worked when up and running and sporadic when idling. Ive been running it like this since 2002, Guess Im lucky Ive been running the same 2 sets of prop's for 13 years never even nicked one. I changed the depth finder and puck out a few times with no change, I know its cored hull and im using the spot in bilge that's cut out/made for the puck/transducer. Ive gota buy new GPS was thinking one w/ transducer. Or what else?
I know at speed/stephull the water is aerated, even 95+ speed o pickup tube is catching air.
Whats your experience? What are you running?
Rob
Livorsi Gaffrig hummingbird lowrance etc
Heres a few Old picks,
Strip Poker 388 is offline
Old 05-04-2019 | 08:49 PM
'05 Concept SF23
I never had any luck with depth finders working at speed in any of my boais.
f311fr1 is offline
Old 05-05-2019 | 09:10 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Active Thunder places them about mid-ship, in front of the step; down at the keel; literally the lowest point in the hull, just off to the starboard side on the flat surface. This is key.
Mine worked 90% of the time at cruise speeds or below. The only issue was in rough water or once the boat aired out; it took settling back into smoother water or slowing down for it to “catch its own signal” again.
I also like knowing the depth finder is a fair amount forward of the drives. If I am inching up to a beach, it’s golden to have that puck 15-20 feet ahead of the drives vs. in the bilge.
Sydwayz is offline
Old 05-05-2019 | 09:54 AM
Rob
Is the ActiveThunder cored up front too?
The Hustler is cut out for the Transducer where the puck in now, I think mine is cored up front to
Old 05-05-2019 | 10:59 AM
Dean Ferry's Avatar
Veteran: Air Force
Strip,
Mine is the same, never worked at speed, THEN, it stop working about a year ago...
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 05-06-2019 | 12:32 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
No, AT is solid fiberglass on the bottom of the boat.
Sydwayz is offline
Old 05-17-2019 | 07:27 AM
Not to derail, but can you give me a quick rundown on the setup? Power,drive, speeds, strake work? I’m pretty sure I’ve read through a few of your re-powers if I’m not mistaken.
apex svt is offline
Old 05-17-2019 | 09:19 AM
Mentalpause's Avatar
NorTech does the same. It is mounted under the head up in the cabin in the CCs forward of the steps. Although you lose the signal at times, it seems to work more consistently than implementations I've had in the engine compartment.
Mentalpause is offline
