Bravo One Upper/Lower studs >
Old 05-18-2019 | 09:54 PM
Rookie's Avatar
Default Bravo One Upper/Lower studs
Anyone have some studs that connect the upper and lower units together laying around? I'm going to remove my 1" drive spacers and do not know where they might have been put for "safe keeping". Need 2 sets for twins. I have 2 drives laying around and just don't want to remove them if not necessary.
Let me know what you have,
Thanks,
Rookie is offline
Old 05-18-2019 | 10:13 PM
I'm sure Sick Stinger has some laying around. You will need shorter upper to lower shaft couplers as well.
Griff is offline
Old 05-18-2019 | 10:34 PM
Sick Stinger's Avatar
Brotherhood #1
I should have 30 or so, believe I have some NIP also
Sick Stinger is offline
Old 05-18-2019 | 10:35 PM
Brotherhood #1
Have shaft couplers also
Old 05-19-2019 | 04:21 PM
Rookie's Avatar
Dang,I forgot the couplers were with them. I will look a little harder. I'll let you know what I find or can't find.
Rookie is offline
Old 05-19-2019 | 08:37 PM
Brotherhood #1
Sounds good, I can get them sent as soon as you know.
Old 07-22-2019 | 03:29 PM
Default 1 inch studs and coupler
Any of you guys have a set of studs and coupler to fit a 1 inch bravo spacer or even a complete 1 inch spacer ?
gerrypantera is offline
