Closed coolant heat exchanger question >
Old 05-19-2019 | 08:42 AM
Talking Closed coolant heat exchanger question
Does anyone know what is plug is ???
Do i need it??
WAS going to plumb power steering cooler from this port, but when i took it apart , i founf this ???
thanks ....
flashgordon is offline
Old 05-19-2019 | 09:43 AM
SB
It's an anode. They help protect against corrosion.
Do not plumb any oil in here unless you want to mix it with cooling water.
SB is offline
Old 05-19-2019 | 09:50 AM
ahhhhhh,,,,,thanks SB
i thought it had to be something like that...
guess i should try to replace them..
or try to clean it up,,,but look pretty bad...
something else to find....hahaha
ahh,,,, found site boatzinc.com
https://www.boatzincs.com/engine-siz...xoCj7YQAvD_BwE
