No throttle response
Hey guys.
I bought a junkyard marine SBC 350 and after mounting a Holley 600 carb I have no sort of throttle response the engine almost cuts if I rev off idle you can see it in the video linked below. It's just a project I wanted to do to learn about these engines which are pretty rare down here in the Caribbean and I can't seem to figure this one out. I have checked the accelerator pump and it works but I may need to check the .015 clearance it requires at WOT. I sort of hooked up the vacuum advance (not sure if it's right) on the distributor and the wires running to the HEI plug on the distributor cap are tight i pulled off the cover and made sure the contacts were not pushed up. Any ideas ? Maybe it's too lean ?
https://www.youtube.com/watch?v=gK8y...ature=youtu.be
No problem but this is how the engine came ! The distributor is a Delco Remy marine distributor and I'm not sure if you realized but the engine is not in a boat and I plan to put it in a car someday. I am using what I have there aren't V8 parts just laying around here in the Caribbean .
Most pre-vortec merc 260hp motors had 8 initial and 30 total.
Lazy neutral revs wanting to intake backfire is usually 1 or more of following and in typical order of what I see for this condition:
Initial timing wrong
Crap in a carburetor passage
Vacuum leak
ignition issue - caap.rotor. wires/ plugs. This includes wires on wrong plugs
Too lean accelerator pump shot
Valves not seating well
Broken valvespring
edit in: watched vid again. You have exhaust water pouring on the ignition wires.
A hei with a vac advance has never been a marine set up
A marine OEM Holley will have J vent tubes.
Vacuum leak
Broken valvespring
I never messed with timing so it's either correct or original owner screwed up !
Carb Passage is clear check that
Will need to check this
Will check If I have a dead cylinder but I know for sure the firing order is right and the rotor is set correctly
accelerator pump is fine tested that
can't answer the last two not that deep into it yet
Thanks Guys
Thanks Guys
