Mercruiser 496 wiring harness needed >
Old 06-01-2019 | 05:27 PM
Default Mercruiser 496 wiring harness needed
anyone have a good used 496 wiring harness that came off a 2004 and up?
AaronTN is offline
Old 06-01-2019 | 11:54 PM
BUP
you need the injector harness in with that as well ? I do have new injector harnesses for the 496 and do have used injector harnesses. And I do have used engine side harnesses for the 496. depending on what you need here will dictate the price.
New is higher than hell.
BUP is offline
Old 06-02-2019 | 08:48 PM
Well, I ended up not needing one after all. It was a crank case position sensor. I was about to cal you as I have your number. Your the go to guy for computer and diagnostic needs. Thanks for replying
AaronTN is offline
Old 06-02-2019 | 08:49 PM
Default PLEASE Delete post
Please delete post
AaronTN is offline
