Thru hull water pick up
My engine builder says absolutely put the key through transom or through haul water pick up on the guy that works on the boat other than the engine says no use the normal pick up through the transom assembly and I’ll drive not sure which way to go
Did you add the sea strainers? if so do you still have the screens in the bottom of the offshore pickups? I was told if you add sea strainers you should remove the screen/grill on the bottom of the pickup.
It may be a long shot but I had sand granuals jam up the nylon check balls holding them open in the thermostat housing. Part #9. Take your hoses off both sides and make sure they are not hung open,
