No water to exhaust manifolds? >
Old 06-18-2019 | 03:54 PM
Default No water to exhaust manifolds?
im running a mercruiser 454 with stock exhaust the riser runs nice and cool getting lots of water but the manifolds themselves are running 170-200 I’ve changed impeller and thermostat. I’ve cracked the lines running to the bottom of the manifolds and there is very little water running through them??
Bill0072 is offline
Old 06-18-2019 | 05:41 PM
There are a whole bunch of 454's in various years and configurations.
Need a motor serial number?
AllDodge is offline
Old 06-18-2019 | 07:53 PM
It’s a 1988 bravo if that helps
Bill0072 is offline
Old 06-18-2019 | 08:23 PM
The 88 does help a bit
Being a 88 with a bravo drive, and mans are hotter then elbows (risers) I'm guessing your cooling system looks like this on the left, same as small block
I would look at the man to riser gaskets first to see if there clogged up
AllDodge is offline
Old 06-18-2019 | 08:31 PM
Yes that’s the one. I can blow the hoses pretty easy right at the thermostat and hear the water bubbling inside the manifold so it is getting a little
Bill0072 is offline
Old 06-18-2019 | 09:32 PM
If you have good flow from thermostat housing I would think rust scale in manifolds could be clogging flow. Maybe take them and acid dip them
Crude Intentions is offline
Old 06-18-2019 | 11:19 PM
Looking at the fluid schematic prev posted, the manifold hoses don't really flow until the thermostat opens, then you get hot (~150 deg) water to the manifolds. Did you check flow to manifolds with eng warmed-up (thermostat open)?
You can buy some reinforced clear hose and temporarily install it just to watch water flow. Safer then pulling off a hose with hot water flowing.
zz28zz is offline
