Hydromotive mounts >
Hydromotive mounts
Hydromotive mounts
Old 06-24-2019 | 03:13 PM
Default Hydromotive mounts
What parts do I need to run switch from a Bravo 1 prop to a Hydromotive? I've not been able to find clear documentation on it.
Thanks, Cole
Cole2534 is offline
Old 06-24-2019 | 03:34 PM
The hub insert is shorter on the hydromotive. You can purchase just the insert with the round rubber pieces. The insert for the bravo is longer and the hydromotive prop will not tighten up if you try to use the insert out of the bravo prop. I went from bravo to P5X hydromotive.
Bama is offline
Old 06-24-2019 | 03:53 PM
I'm looking to mount a Quad-IV.
Got a part number?
Cole2534 is offline
Old 06-24-2019 | 04:03 PM
Steel Drive sleeve 850821Q12
Bama is offline
Old 06-24-2019 | 04:24 PM
Boom! Thank you. I still haven't been able to get them on the phone.
Cole2534 is offline
