Apache Scout Chine Walk >
Old 06-27-2019 | 08:02 PM
Default Apache Scout Chine Walk
I recently did a complete (1000 man hr) resto on a 1988 Apache Scout. This is the 22' with the euro style transom. Bobby S. told me he only built a dozen of them and says he loved the way the boat handled with the 25" transom as opposed to the bracketed 21'. Of course back we had 200's and 225's and the boat ran 60 to 65 mph.
I built a 300hp E-TEC with .58 ratio L2 gc. I'm turning a 26" Raker at 5850rpm @77mph (9% slip). I installed SeaStar Pro 2.0 helm and Pro cylinder(no air in system and end play is within specs)
I'm looking to hear from anyone with experience setting up and running a similar boat. I have experimented with mounting height and props and feel that I have the best combo but the chine walk above 70 is pretty severe and I can't always drive out of it.
The boat bottom is very nice, strakes are straight and sharp, running surface is flat with no rocker or hook and even from side to side. 6" tapered mini-pad is symmetrical.
  • Should I install solid mounts? both upper and lowers?
  • trim tabs? (I don't really want em)
  • any experience shared would be much appreciated.
Thanks guys
Dave
dbelus is offline
Old 06-28-2019 | 10:29 AM
I would ask over on the scream and fly sight. Lot of outboard go fast boaters over there
smokediver is offline
Old 06-28-2019 | 10:57 AM
J-Bonz's Avatar
99 problems and chine walking ain’t one of them. Wish I could help but I am still running a 200hp Merc & a pot luck prop on it and just touching 60. I agree with posting on S&F
J-Bonz is offline
Old 06-30-2019 | 06:52 PM
Went back through my steering system and found that the steering cylinder stop had backed off from the tilt tube allowing just a little end play. Tightened it back up and the chine walk is back to being manageable. In the high 70's and lookin for 80 now :-)
dbelus is offline
Old 06-30-2019 | 09:02 PM
J-Bonz's Avatar
Good find! Good luck on your quest. Someday I will go bigger. Keep saying when the 200 goes but it just keeps rolling along...
J-Bonz is offline
