Oil pump failure
Put a mild built 454 in my boat for the summer while I rebuild my 496 blower motor. After the first hour on the water I lost oil pressure. It has a melling m77hv after I got it home I pulled the dist. And with my priming tool and drill can build almost 50lbs of pressure. Put the dist. Back in and cranked it and it won’t pump any. There is also a lot of play in the pump shaft now. I measured the dist. Shaft length and distance from the pump shaft to the intake mating surface and that’s correct. Wondering if anybody has any insight on what could have gone wrong before I pull the motor. Unfortunately I think the boat is done for the summer after only one trip out.
Engine will still run and the distributor rotor turns so the cam is still together. I might throw a stock distributor in it and see if it will build pressure. At this point I’m just trying to figure out what’s happening because I’m gunna have to pull the motor out and apart to see what all damage came from the loss of oil
If the engine runs/rotor spins the gear is fine.
If the priming tool builds pressure, the oil pump and it's drive rod is fine.
Must be the male 'key' in the distributor gear that's gone. Never head of it breaking but every few months it seems I run into something that I'm working on that I've never seen either.......so.....pull the distributor and turn it upside down and look at it.
