Supercharger water intecooler feed line >
Old 07-11-2019 | 09:35 AM
Default Supercharger water intecooler feed line
Where is the best place to connect the water supply line to the supercharger water intercooler? Currently its has a tee fitting on the hose that goes from the outdrive to the seawater pump...
r,
Eric
es99eliminator is offline
Old 07-11-2019 | 10:11 AM
F-2 Speedy's Avatar
most run a 2 stage sea pump,
F-2 Speedy is offline
Old 07-11-2019 | 10:37 AM
resurrected's Avatar
I run two independent pickups and dump lines for the inter coolers
resurrected is offline
Old 07-11-2019 | 10:55 AM
Separate thru hull pickup
MILD THUNDER is offline
Old 07-11-2019 | 11:04 AM
resurrected - are you pickups through hull as well?
Old 07-11-2019 | 11:36 AM
Yes they are, the set up is new to me this year. In the process of reassembling, so no actual results. The reason I went with independent pickups instead of 2 stage pump was, at idle a cold inter-cooler can cause fuel to condense.
177 Weiand Blower with Holley Sniper
Sales staff at Teague advised that I shouldn't need pressure blow off valves at the 80++mph top speed I am hoping to get to
-10 pickup and supply with 2 x -8 dumps
Old 07-11-2019 | 02:02 PM
GPM
If you live in a hot climate area, you may want to push water through it all of the time so it doesn't detinate after idling for any length of time.
GPM is offline
Old 07-11-2019 | 02:27 PM
Mine are plumbed off the sea strainer.
payuppsucker is offline
Old 07-11-2019 | 07:58 PM
Multiple ways of doing it but as mentioned above climate and water temps have a lot to do with how you want to plumb it.
IGetWet is offline
Old 07-12-2019 | 09:33 AM
mine idled like **** at ROTO with full time water going thru the cooler. I added separate pickup . and a drain so water doesn`t sit in them when not in use
ICDEDPPL is online now
