Holley HP EFI install will only spin to 5150 >
Old 07-29-2019 | 12:02 PM
Default Holley HP EFI install will only spin to 5150
A holley hp efi was installed, limiter was set to 6300, hard limiter set to 6500 (yes very built engine) Engine will not spin past 5150.
Nordic Heat built 496 540 pro charged and make max hp at 6300.
I am thinking something left over form the old ecm or smart craft system is keeping it from moving past 5150.
Cerberus66 is offline
Old 07-29-2019 | 08:03 PM
Rookie's Avatar
Did you make a prop change at the same time?
Rookie is offline
Old 07-29-2019 | 09:18 PM
What ignition? Spark plug gap?
underpsi68 is offline
Old 07-29-2019 | 09:21 PM
Tinkerer's Avatar
do you have 8 coils or another ignition control that is wired to the single coil?
That side car ignition control could have you limited to 5150
Tinkerer is offline
Old 07-30-2019 | 12:43 PM
we found this, spark plugs are gapped to .060 should be .035, airfilter is too small and engine is collapsing it. I was told to run my LS style coils and see if i have one out. All that could lead to the problems. We run an Holley HP efi system on a LS based ignition.
Old 08-05-2019 | 12:57 PM
Gap pulled to .045 and BAM rpm
Old 08-05-2019 | 01:08 PM
SB
Good news !
Maybe the 496/8.1L crowd will listen to me now (staying with the dumb OE spec of .060") and stop burning out their wires and coils. Someday maybe. One day closer ? LOL.
Again, great move on your part and thanks for letting us know.
SB is offline
Old 08-05-2019 | 09:28 PM
Rookie's Avatar
Originally Posted by SB
Good news !
Noted... I'm getting ready to change the plugs on my 496 2500 Avalanche.
Rookie is offline
