Should a 12 meter spin in or out?
Sorry to ask this question, i know its been asked a million times, but searching the forums its hard to find an answer to this question for my 12 meter straight bottom as most are for stepped hulls. I have #3's and currently spinning out. Everyone says "in to win" but just wanted some advice from people that have ran both ways with this hull as swapping drives is a pain. With the props spinning out i definitely get stern lift and the bow stays down. I assume with more bow lift i will get less drag in flatter water but curious if its worth it or not. Appreciate any advice!
Charlie
That helps with my side by side as well. If you don't they pretty much will do nothing in reverse. Like you say when you tilt up the prop wash goes under the boat and for me doesn't really seem that bad then.
Agreed, a little up from neutral does make a difference. Side by side here as well, high X and spin them in.
After switching them around I definitely gained some bow lift and probably 3-4 mph too. It was flat water and full on fuel so might be a touch more than that. Was worth the time of switching them for sure
