methods to purge milky oil from engine
My buddy's 2006 330 SS Formula with 6.2l SBCs had a cracked exhaust manifold on one engine. We are replacing everything in the exhaust with new parts. He only ran the boat at idle before it started running rough. I pulled all the plugs on the odd side of the engine and did a compression check to make sure it wasnt a blown head gasket. I got about 110 to 130 psi on the odd side of the engine. The engine has 400 hrs on it and the boat was a salt water boat from Florida now up in Michigan. I figured the compression is low because of any goopy oil stuck around the rings. Ill check the compression again after we fire up the motor and dry it out. I would have to estimate about a gallon of water got into the oil. I was able to suck out pretty much all of the milkshake oil. The engine was never run under load with the milky oil. I told him we would have to do maybe 3-4 oil changes or until the oil looks good again. What ways have other used to purge the remaining milkshake out before calling it good? I have heard of using kerosene, or Marvel Mystery oil mixed with the oil.
Sorry to say, but that compression is too low.
Suck the water out, change oil with the cheapest stuff you can find. Repeat as many times as needed until condensation is no longer under the valve covers or on the oil fill cap.
I had a 3.0 merc in my houseboat do the same thing, its a tractor engine that will last forever, but I was able to save it by sucking the water out of the oil a few times with an extractor, then changing the oil 3 times.
Good luck. If that doesn't work, pull it and rebuild!
Change it 3-4 times with cheap oil, then fill it with oil that doesn't have an emulsifier, start it and run it for a short period, then let it sit. the water and oil will separate, water on bottom. Change the oil again, put you normal oil in it and get it hot to evaporate the rest out.
compression is probably low because the oi milkshake makes it slow to turn over.
All good info.
Ayuh,..... I do it differently than the above posts,.....
I'll drain/ pump out all of the contamination I can, refill the oil, 'n then run it up to temp,.....
The tiny bit of water left in the oil system steams off in a few minutes,.....
No need to waste several gallons of motor oil,......
and I do it different than all you guys,,I pull intake and valve covers,clean up the inch of sludge first,vac,heat gun,towels,suck what I can from the pan.then put all back together.fill w/ cheap oil and some diesel(~ quart) run till warm and then some w/ pcv system working if equipped or open fillers(allow water that remains to boil off).
change that oil,then repeat 1 more time.fill w/ synth. oil and take boat out for a moderate ride and motor oil under valve covers.
all the water doesn't steam off in minutes.
well, as mentioned above, i would pull valve covers clean under there,,pull intake ??? could , not sure if i would
get out as much fluid , water , oil etc...as you can. Then , some chaep oil , run it up to temp., check ,,did it again...
may take a few times, did this years ago on sbc i put together a guy
old wood boat , was taking on water,,almost sunk,,,and evetually it did stink in north channel.
I remember one time I fill a motor with water. Flushed 3 or 4 times and realized it was not helping he bottom end knock so I took it apart and you would be surprised on how much water (white oil) was still in there. After you get it clean run it easy until … I don't know.
