96 454 mag won't start >
Old 08-17-2019 | 05:20 PM
Default 96 454 mag won't start
Hello everyone. I have a 96 Baja 252 with 454 mpi mag. Last week the starter was staying engaged and also noticed when I put the boat in the trailer that it wouldn't restart. I just figured it was from the bad starter. I replaced the starter and took it out today. Starter did great but after an hour of boating I shut the boat of and it wouldn't restart for a half hour. It wouldn't click or turn over. Everything else had power. I'm sure it's a control module or something breaking down after getting hot. Had anyone had this problem
bigcarter62 is offline
Old 08-17-2019 | 05:52 PM
I'm thinking slave relay
When it won't start, jump across the top larger terminals of the relay, and if it turns over, that's probably it.
Would need a couple other test to make sure its not the key switch
AllDodge is offline
Old 08-17-2019 | 08:18 PM
It's not the key switch. I had that tested.
Old 08-18-2019 | 12:33 AM
Neutral safety switch?
zz28zz is offline
Old 08-18-2019 | 05:44 AM
Replaced the neutral safety switch also. But thank you
Old 08-18-2019 | 07:38 AM
did you jump across the big terminals of the slave solenoid?
sutphen 30 is offline
Old 08-18-2019 | 03:16 PM
Yes, make sure the shifter is in the neutral position, and the key is in the run position, before you short out the 2 big terminals with a screwdriver.
Do you have a safety lanyard on your boat ? If so, make sure that is in its proper position as well before trying to start it this way.
350scarab is offline
Old 08-18-2019 | 09:51 PM
I worked the shifter back and forth and wouldn't start. I could hear a click when I'm neutral. I replaced the safety switch just because it was original. Next time I'm out I'll try jumping the solenoid to see if it starts
Old 07-26-2023 | 02:19 PM
Sooo what was the results of this?
xxxtreme36 is offline
Old 07-26-2023 | 03:16 PM
The result is that embarrassing moment you realize the thread is 4 years old.
techman is offline
