Link bar lifters and valley pan 525efi >
Old 08-23-2019 | 08:35 PM
Default Link bar lifters and valley pan 525efi
How are you guys modifying 525efi block valley pan to run link bar Johnson lifters? Dont want to put it all back together and have them hit...
382fastechh is offline
Old 08-24-2019 | 08:00 AM
we left the tray out...others modify.
1MOSES1 is offline
Old 08-24-2019 | 11:52 AM
I read running without it can cause oil consumption due to the PVC valve being directly above the tray?
Old 08-24-2019 | 12:12 PM
F-2 Speedy's Avatar
If you're running the stock lower plenum I would not remove it, as you read its an issue with the PCV location
F-2 Speedy is offline
Old 08-24-2019 | 03:26 PM
Leaving it out will cause oil consumption. I quickly replaced them on my 525s when I figured out what the issue was. No more problem.
endeavor1 is offline
Old 08-24-2019 | 07:06 PM
You guys make it sound like relocating the pcv is an act of god...plug the old one and throw it in one of the heads. Done. We’ve been running it fine for 3 years.
1MOSES1 is offline
Old 08-24-2019 | 07:37 PM
TomFTM's Avatar
Call bill at ateco he has modified valley pans on the shelf .
TomFTM is offline
