Deselecting overdrive
Old 08-26-2019 | 06:42 AM
Default Deselecting overdrive
I will be towing about 9,500 pounds ~600 miles from central North Carolina to Pensacola, Florida. I may try to avoid Atlanta traffic so I will using I-85 or a more southern route through Ga./Al.
My question is, should I de-select overdrive on my transmission (and what are the pros/cons for doing so).
I have a 250,000 mile, 2000 V10 Excursion with towing package and electric brake controller (trailer has a Hydrastar EOH braking system).
Thanks,
Tom
F14A water jet is offline
Old 08-26-2019 | 10:44 AM
Depends on the load, grade and speed imo. I don't put my Tahoe in trailer mode ever when towing my boat -6500ish lbs. Never needed to. I would watch tranny temp and feel how engine is running. If it's lugging or tranny temp is hot than turn off od.
underpsi68 is offline
Old 08-26-2019 | 12:50 PM
As far as traffic is concerned, I use the App "Waze".... its a freebe that will alert you to traffic snarls and reroute as well as radar trap/sitting police up ahead - not just here in North America but i have used it around the EU as well.
If you have a trans temp gauge, it can dictate what you can get away with... The trailer mode give a higher shift point (possibly harder shirft and may not give top gear as in a "sport mode" car) if your truck is popping and dropping through gears in the hills - cheaper to pay for the gas than a trans. once you are in an area where you can get up to speed and the truck is not laboring, I opt for the mileage and go back to trailer when coming up to a hill.
9500 is a good pull...how old is the trans fluid?
speicher lane is offline
Old 08-26-2019 | 01:25 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The only time I’ve ever locked out OD when towing was in the mountains, on any of my trucks, ever.
Else, just select the tow/haul mode (if equipped) and send it.
I agree on the transmission temp gauge, invaluable info.
Sydwayz is offline
Old 08-29-2019 | 05:14 AM
That truck should have an automatic tow/haul mode, meaning there is not a tow/haul switch to engage.
Ultraboy is offline
Old 09-14-2019 | 06:09 AM
articfriends's Avatar
Its not common on Ford 4r100/E40d like your excursion has to need to put in 3rd from 4th unless it going in and out of lockup as trans is quite beefy unlike some 1/2 ton stuff, Smitty
articfriends is offline
