Does a small block with a roots style blower need premium fuel? >
Old 08-27-2019 | 02:54 PM
Default Does a small block with a roots style blower need premium fuel?
Just curious if it possible to run 87 or is premium always required?
Alwhite00 is offline
Old 08-27-2019 | 02:56 PM
SB
Any more info ?
That being said, big chances are no, it should use premium.
But that answer has as much info as the opening post.
SB is offline
Old 08-27-2019 | 05:28 PM
depends on how much compression in engine and amount of boost. higher the total compression the higher the need for high octane so you dont blow up pistons (detonation).
Swamplizard is offline
Old 08-27-2019 | 06:01 PM
Thats like asking if you always need an umbrella when its cloudy out.
if your static compression is 7.5:1 and your running 3 psi of boost with an intercooler and aluminum heads...no
If your static compression is 9:1 and your running 7 psi of boost, the answer is yes
If your somewhere in between, you need to break out the slide rule.
phragle is offline
Old 08-27-2019 | 06:31 PM
TURBOED's Avatar
boost adds compression, i would use premium
TURBOED is offline
Old 08-27-2019 | 06:37 PM
I wouldn't run 87. Gas is cheaper than a rebuild.
underpsi68 is offline
Old 08-27-2019 | 07:04 PM
thank you you for the informative answer, that answers my questions.
Old 08-27-2019 | 07:17 PM
Skip down to effective comp ratio. You can run about 9.0 CR on 87 octane.
https://documents.holley.com/techlib..._tech_info.pdf
Griff is online now
Old 08-27-2019 | 09:01 PM
DOES ANYBODY ON here run a blower motor on 90?
I ask as here most on the water is non ethanol 90,,,,,, can not find higher octane on water.
Wildman_grafix is offline
Old 08-28-2019 | 08:06 AM
The struggle is real. We had 2 marinas with 93 on our lake - both of them dropped it this summer. My marina added mid-summer, but only in a 2000 gallon tank, so on busy weekends it goes fast.
I resorted to filling up on land and run till its gone.
TM
ALL_IN! is offline
