575 SCI rebuild >
575 SCI rebuild
575 SCI rebuild
Old 09-02-2019 | 08:35 AM
Default 575 SCI rebuild
Multiple threads on these engines. Bottom end now has 410 hrs. Just did a leak down test and it appears I’m due for another top end rebuild. Time to pull the engines and go for a complete rebuild? I’d be looking for +700hp.
kjm5125 is offline
Old 09-02-2019 | 10:28 AM
change the heads and cam,lower the compression a bit.
sutphen 30 is offline
Old 09-03-2019 | 09:52 AM
Roller cam, Intercooler, freshen blowers, and pulley for max boost.
c0ncEpT is offline
Old 09-03-2019 | 11:23 AM
Currently running Whipple Inner Coolers and smaller pulleys. I am thinking about 871's. Trying to decide if its time pull the engines and go for the complete rebuild.
kjm5125 is offline
Old 09-03-2019 | 12:14 PM
i did mine at 15X
refreshed bottom end rings and bearings, stock merc components,
525EFI cam
AFR CNC 305 heads - big chambers dropped compression even lower then stock
.040MLS head gaskets,
dyers 8-71 kit
eddie young EFI ontop
Holley HP as the mefi **** the bed on the dyno -
made 775hp on 4psi at 5900 un cooler
with the whipple cooler im sure you can do a super easy 8XX
LTZCrew is offline
Old 09-03-2019 | 06:31 PM
Originally Posted by LTZCrew
i did mine at 15X
525EFI cam
dyers 8-71 kit
Do you have any pictures?
kjm5125 is offline
Old 09-04-2019 | 11:03 AM
At 410 hours, I think I'd just do complete refresh.
Eddie Young did good (top end only) on some 575's we had. Heads, roller cam, tuning, etc.
ALL_IN! is offline
Old 09-06-2019 | 09:35 AM
LTZCrew is offline
Old 09-06-2019 | 10:21 AM
1 MAIDEN AMERICA's Avatar
I went .030, cleaned head and deck, 525 roller cam(I think), Super Chiller w/slightly smaller pully, stock fuel system, stock MEFI
Cam I .610/298* E .632/306*
Press fit pins and cast iron heads
Stock oil cooler
703HP@5372 740TQ@4100
4# boost
92 octane
Ed Trihey @ Ed's Automotive assembled/dynod them
310 hours and still run the same based on top speed of boat hasn't lessened.
WOT oil pressure 38PSI@170F@5350RPM for 10 minutes+ freaked me out but 310 hours later I guess it works and it's easier on the distributor gear.
1 MAIDEN AMERICA is offline
Old 09-07-2019 | 08:07 AM
Thanks guys, a lot of good information.
kjm5125 is offline
