Original cockpit switches 87 242ls >
Old 11-09-2019 | 05:23 AM
Default Original cockpit switches 87 242ls
Does anyone know where I can purchase original Formula cockpit switches? I'm planning on replacing two aftermarket switches with originals.
Thanks in advance
Tony S.
Tony S is offline
Old 11-09-2019 | 06:41 AM
You are going to need to find somebody upgrading their dash.
These breaker switches are no longer made and are absolutely impossible to find and when you do find them they are usually very brittle and expensive.. Keep a sharp eye out for somebody parting out an older formula.
Good Luck
GLENAMY 242SS is offline
Old 11-11-2019 | 10:07 AM
I had the same issue with my 1988 red toggles. I replaced them all
oconnor marine is offline
Old 11-11-2019 | 01:59 PM
I gave all of mine to a guy that posted on here a year ago. You are 12 months late. Be sure you get the right switches because they are amperage specific on the old red toggles. Switch/breaker.
ph1971 is offline
Old 11-11-2019 | 02:06 PM
I almost did the picture above with regular toggles and fuses. But I kept the factory ones. They are still available in solid black but obviously arent lighted.
Redneckcustoms13 is offline
