Bravo fresh water pump >
Old 11-10-2019 | 10:01 AM
Default Bravo fresh water pump
Normally the pump is mounted on the left side of the block I have a 31 American offshore changing my motors and rigging using bravo pumps with mechanical fuel pumps can you mount the pump on the right side of the block
mbasile1982 is offline
Old 11-10-2019 | 01:08 PM
The 3 that I have had were mounted on the RH side of the block. (Starboard side)
Alwhite00 is offline
Old 11-10-2019 | 03:16 PM
Same here. Raw water pump and mech fuel pump are on the same side of both engs (right/starboard side). Raw water pump is down low.
zz28zz is offline
Old 11-10-2019 | 05:12 PM
Ok cool just checking cause most are on the left of facing the motor
Old 11-10-2019 | 06:33 PM
Facing the engines the left side is Starboard. I have never seen them mounted any other way.
1BIGJIM is offline
Old 11-10-2019 | 06:46 PM
Correct I’m asking if you can mount them on the right side of the motor in a cat the port motor there’s more room on the right side
Old 11-10-2019 | 06:56 PM
If you have room in front of the motor, use a crank mounted water pump
AllDodge is offline
Old 11-10-2019 | 08:29 PM
Yea I would do that but I want to do mechanical fuel pumps I know I’m a pain in ass lol
Old 11-11-2019 | 01:27 AM
I see no reason that you can't put it on the other side, but you would probably need to have a custom bracket made.
Griff is offline
Old 11-11-2019 | 06:41 AM
I didn’t think it would be just didn’t know if anyone did it before
