Whippled 500EFI cam question >
Old 11-16-2019 | 07:31 AM
Default Whippled 500EFI cam question
I did a search and couldn’t find an answer...I’m adding 3.3l whipples to my 100%stock 500EFIs this winter...bottom ends are fine going thru top ends... my question is, i have a pair of 651 cams, would they be too much cam for 500EFIs or should I look for 741s or should I just leave the stock cams in place since I’ll only be about 700-750hp with stock bottom end?
lucky cat is offline
Old 11-16-2019 | 07:33 AM
I'd upgrade to the 741,it will get you to the 750 mark.I've done them w/ the 8.1l cam thats a double swap and 240,248,,thats a really nice upgrade.
you have some one to retune it?
sutphen 30 is offline
Old 11-16-2019 | 07:38 AM
F-2 Speedy's Avatar
What ECM are you planning on using
F-2 Speedy is offline
Old 11-16-2019 | 08:25 AM
if i had the 651 cams i would use them,i have used them in a 502 before with good results.
mike tkach is offline
Old 11-16-2019 | 08:33 AM
Pretty sure it’s a MEFI3....I’m located in Michigan and I only know of a couple places here that Can tune the MEFI is Arcticfriends on the other side of State or Tyler Crockett over in Detroit...
Old 11-16-2019 | 08:40 AM
F-2 Speedy's Avatar
Smitty is your guy, we've done business for a few yrs now, he did my Whipple injectors last yr and have done a couple other sets also
Old 11-16-2019 | 09:00 AM
articfriends's Avatar
I think we talked before, I have family with a cottege /house in Canadian lakes near Hardy so we could probably meet up over there and run it on the water. Even better though would be for you to drag a motor over and dyno it so we could make sure everything's good and get tune close before going in boat. I just Dynoed a 502 w whipple sidemount for john lambrestge / polebarn racing engines over your way , hes at hardy alot camping, Smitty
articfriends is offline
Old 11-16-2019 | 09:12 AM
yes, Smitty, I called you a few weeks ago..I almost bought a pair of 2.3l whipples but someone got there first...happy I lost out because I found a set of 3.3l with MOAC intercoolers for pretty much same $...do you have any input on the cam?
Old 11-21-2019 | 10:25 PM
You can PM me. I just built a pair and made 760 @5400. I can give you some cam specs and grind info. Was on 3.3 Whipple 509 with 088 heads. Warning! do not send your boxes to Whipple for a flash, they lock them and only a few people can unlock them. Actually 2 come to mind. Good tuners out there and can give insight but I can help with an cam as well.
larose481 is offline
Old 11-22-2019 | 07:58 AM
rv
I have a pair of 651 cams available if you want to use them.
rv is offline
