External water pickup 24x7 hull >
Old 11-17-2019 | 11:56 AM
Default External water pickup 24x7 hull
Im putting together a Carrera SS7M with a 454 Mag and Bravo. The transom assembly I got looks like it has a combination of a corrosion restricted water hose and/ or somebody filled the water pass through with silicone or something . I’m thinking of going with an external pickup and sea strainer . I used the search button a little but I was looking for more info or pictures . I don’t have the nerve to drill a hole in the bottom of the boat , so I want a through transom type . I think I like the stainless steel adjustable type from Hardin marine , but I’m open to ideas as far as brand , type etc. Also looking for any input / experience on where exactly to mount it in relation to the V of the boat . The water intakes are still open on the Bravo drive as well ( just an early Bravo 1 nothing special)Thanks in advance .
tooslow is offline
Old 11-19-2019 | 01:49 PM
Also intrested about know the best solution.
JaniH is offline
Old 11-19-2019 | 02:09 PM
I think I should have posted this question in the general tech section . Not getting much action here . Through my research I’m thinking about 8-10” from the “ keel “ for the external transom mounted water pickup , then use the water intake system on the drive to make a drive cooler of some kind .
tooslow is offline
Old 11-19-2019 | 04:30 PM
you still want the water to go thru the drive for cooling. on the last super cat light I built I ran the water thru the drive and up and out above the drive and let it dump on the top to cool the upper
compedgemarine is offline
Old 11-20-2019 | 06:59 AM
My 89 38 scarab has transom water pickups,,,then the sea strainers..to the coolers
it works...my setup
flashgordon is offline
Old 11-20-2019 | 09:41 AM
Why not just fix your transom assembly ?
phragle is offline
Old 11-20-2019 | 10:14 AM
it works...my setup
How difficult is it to clean your sea strainers when the drive train is in there
green lightning is offline
Old 11-20-2019 | 10:26 AM
with all the boats being parted out
agree to why not just get a good bravo transom assy
they are lots cheaper than all the work and materials for transom pu
johnmiffco is offline
Old 11-20-2019 | 11:47 AM
Thanks for the info guys . The more I read on this subject I think I will just put a new water hose replace / repair kit in the Bravo transom assembly . Then I don’t have to dial in transom pickup / water pressure etc etc
tooslow is offline
Old 11-22-2019 | 07:22 AM
Talking
with engine hatch on,,,it would be tuff getting strainers.
but with hatch off, i can get to them
thats why i want to change hatch to barn style opening
