Boat Bay Progress
Old 12-01-2019 | 05:52 PM
enzo thecat's Avatar
Default Boat Bay Progress
My wife said I can buy a cigarette but I had to build her a new house first. I had the house designed with a boat bay. It will have hot/cold water spigots and a sink. Shopping for tool chests now. Thinking of trying out a couple of 73" Icon tool cabinets. I originally had 14' ceiling to accommodate a 12' high door. It was framed up but once we saw it in person it ruined the exterior elevation on that side of the house. I had the framers take it down and re-frame it to 12' high ceilings. It now has a 10' high door (by 12' wide) That corner of the house looks much more appropriate now. One annoying consequence was that the builder forgot that I wanted 2 drains in this long bay. Instead he only put in one. it is sloped well so it will drain. Pisses me off every time I look at it but its not worth the cut and patch work that will be required to add it now.
enzo thecat is offline
Old 12-01-2019 | 11:32 PM
Moses's Avatar
That looks sweet! What size Cig are you looking to park in there? I was looking to start my garage build soon and was wondering how high to clear a 38TG. Also wanted to make the roof high enough to lift the boat off the trailer Incase I wanted to maintenance the trailer or underside of the boat.
Moses is offline
Old 12-02-2019 | 07:07 AM
Indy's Avatar
Member #154
Very nice!!! I could live in there no problem, the wife could have run of the house, gimme a TV in there, shower, room for a cot, a nice boat and I'm good to go!!!!!
Indy is offline
Old 12-02-2019 | 09:17 PM
Thanks. I don’t know what size boat yet but nothing smaller than 38’. It will most likely depend on the best deal I can find at the time. The bay is 57’ long so I imagine the max will be 42’ on the trailer.
Old 12-03-2019 | 06:23 AM
Indy's Avatar
Member #154
Why are there spacers in the sheetrock seam down the middle?
Indy is offline
Old 12-03-2019 | 07:39 AM
Sydwayz's Avatar
Forum Regulator
Put in a plug on it's own 30A circuit/breaker and label it "shore power" for plugging in the boat. Often, they are on the port side of the boat, but that's not a rule, so you could put one plug on each side of the bay/ 1/2 way down.
I just saw this post, and was going to recommend that you go back to the higher ceiling and door height. You could have always built a valence across the front of the door to hide it's height. I too went with 10' high doors and 12' high ceilings. And then I ended up with a toy hauler for my race car, and a fostered pontoon boat that are both 13 feet tall. Doh!
Sydwayz is offline
Old 12-03-2019 | 10:28 AM
You can fit a Gladiator in there nicely!
Poker Face Xtreme is offline
Old 12-03-2019 | 03:18 PM
common practice to leave space for installation of expansion joint, but it would usually be installed every 30 ft., not necessarily dividing the room.
offshore312 is offline
Old 12-03-2019 | 04:22 PM
30 Amps!!!???? What am i going to be doing with the boat that will have that kind of draw?
Also it wasnt the garage door that looked bad. I was trying to keep it. The problem with the higher ceilings was how it changed the roofline on that corner of the home. I wasnt going to bastardize the whole house for this. Besides, it will only ever hold a cigarette or cars. If I need more than this, I'll build another building on the property ( if I ever recover from building this)
Old 12-03-2019 | 04:36 PM
F-2 Speedy's Avatar
You can probably get a Marauder in a 57 ft stall.................the 20 or 30 amp twist lock plug is standard for the marine industry and most are 120vac
F-2 Speedy is offline
