head gasket advice >
head gasket advice
head gasket advice
Old 12-03-2019 | 09:03 AM
Default head gasket advice
I installed the Fel Pro 17030 perma torque head gaskets on my small block chevy. I of course did not follow the instructions that say to torque the head and then wait 10 minutes and then loosen each head bolt and then re-torque theme at a time in sequence.
I am running edelbrock aluminum heads and arp head studs
The engine probably has about 15 minutes of run time on it, but has been assembled for a good 6 months or so.
As I see it, my options are
1: replace the head gaskets with new ones and follow the instructions
2: go back now and complete the install procedure by loosening and re-torueing each head stud one at a time in sequence
3: send it
What do you guys suggest?
Thanks,
Russ
highplainsdrifter is offline
Old 12-03-2019 | 10:00 AM
i never retorque them and never had a problem.through the years i have installed hundreds of them with 0 issues.
mike tkach is offline
Old 12-03-2019 | 10:15 AM
F-2 Speedy's Avatar
Same here, but I do use the ARP Ultra Torque Assembly Lube
F-2 Speedy is offline
Old 12-03-2019 | 10:26 AM
SB
You can do what you think is better.
But, like you mentioned option #3, I make like Larry Enticer on felpro permatorque head gaskets.
SB is offline
Old 12-03-2019 | 10:42 AM
as do i.i apply it on both sides of the washer and i use leak lok on the threads that go into the block.
Old 12-03-2019 | 10:45 AM
articfriends's Avatar
Ive never done the torque and re-loosen, I have went over them twice at max tq though, I wouldnt give it another thought, Smitty
articfriends is offline
Old 12-03-2019 | 02:42 PM
excellent, thanks for the responses. That's a consensus where I come from.
I used the arp ultra torque assembly lube as directed as well.
I am going to send it.
Russ
Old 12-03-2019 | 03:28 PM
F-2 Speedy's Avatar
Torque the head bolts from the center to the outside in a 3 step sequence, I take them all to 40 then to 60 then to the finish spec around 70-75lbs depending on application
Old 12-03-2019 | 05:08 PM
#2 and send it!
sailtexas186548 is offline
