Best Blower Carburetors for BBC 598 Boost Referenced >
Old 12-08-2019 | 10:33 PM
Default Best Blower Carburetors for BBC 598 Boost Referenced
I need 2 1050 or 1150 Dominator for my Bbc Chevy 598 Ci 14-71 TBS with Chiller running 8-10 psi .
Any info on AED,Prosystem,Nickerson,Rd Racing,or any other Carburetor Shop. does the boost reference make a difference or not needed would like to get more info.
FORCEINU is offline
Old 12-09-2019 | 07:48 PM
Are you ever not in boost while on plane?
Boost referencing in a marine application makes no sense. Pvs are open the whole time while under boost (99% of the time) so whats the point of unmetered fuel getting dumped into the carbs.
I did all my fueling with jets. No boost referencing, no PV`s .
out of the box 1050 quickfuels were great, You don`t need a carb shop, it`s a waste of $$ .
Nickerson modifier carbs that were on the boat when I bought it were piles of junk with a horrible fuel curve
ICDEDPPL is offline
Old 12-09-2019 | 07:53 PM
BBYSTWY's Avatar
May want to price out going EFI instead of the carbs..might surprise you and be cheaper honestly. Other than that I agree with above...talked with ICDEDPPL and Mild thunder both when I had carbs and pulling the power valves and jetting up made a big difference in mine...Idled better, came on plane better, less soot on the transom
BBYSTWY is offline
Old 12-09-2019 | 08:01 PM
cigrocket's Avatar
I had King Demons on my 10-71 blowers. They were easy to adjust. Idle was great.
cigrocket is offline
Old 12-09-2019 | 08:31 PM
bck's Avatar
bck
Charter Member#568
Dont waste money on ProSystems, very disappointed with the carbs and their support. The best carbs are fuel injectors.
Straight bottoms and flat decks
bck is offline
Old 12-10-2019 | 10:35 AM
1150s feeding 598s with 1671s boost refenced with no problems , you'll be glad you did
PartyBarge22 is offline
Old 12-12-2019 | 02:26 PM
I have had several done by Patrick @ Prosystems, would use them now with no worries..not sure the story on post above...
ezstriper is offline
Old 12-12-2019 | 06:32 PM
bck's Avatar
bck
Charter Member#568
If by the post above you are referring to me- the carbs were **** and his nonexistent customer service was ****. I used them one season and replaced them with Quick Fuels. I could elaborate on every detail but this isn't a post about my carb problems. I just gave the OP my opinion to use as he will.
bck is offline
Old 12-13-2019 | 09:27 AM
Fuel Injection , Better Starting , Better Idle , Less Soot , Better Fuel Control .
dunnitagain is offline
