out drive swap,bravo 2 to 3 ??? >
Old 01-04-2020 | 08:50 PM
Default out drive swap,bravo 2 to 3 ???
I have a 93 sea ray 290 sundancer just repowered a 7.4L ,anyway the out drive is a 96 bravo 2 and the skeg is destroyed,my ? is can I swap out the lower unit with a bravo 3 with out changing the upper unit ? Also can I redirect the suction side of the cooling pump from the out drive to a thru-hull supply ? THANKS GUYS FOR ALL YOUR HELP
kroot is offline
Old 01-04-2020 | 09:27 PM
t500hps's Avatar
21 and 42 footers
Yes and Yes. Although making sure you're getting enough water in a thru hull pick up could be difficult to determine. Might be able to find someone with the same BIII on that boat to find out what props it needs????
t500hps is offline
Old 01-04-2020 | 10:40 PM
BUP
Bravo 3 pumps the same amount of water flow as Bravo 1 and 2
BUP is offline
