Baja 33 496 HO's 28P 4 blade >
Old 01-10-2020 | 05:53 PM
Default Baja 33 496 HO's 28P 4 blade
33 Baja Outlaw SST
Ywin Merc 496 Mag HO's
Bravo one drives
Bravo 1 4blade 26p props
Anyone running a simmular boat and set up with
Bravo 1 4blade 28P props. ?
thank you
Bart
bacino1960 is offline
Old 01-11-2020 | 11:24 AM
I am currently running 28's on my 33
HIVOLT is offline
Old 01-11-2020 | 01:00 PM
Default 28p
What kind of numbers are you getting if you dont mind me asking ?
RPM
speeds.. wot
thank you
Bart
Old 01-11-2020 | 01:30 PM
5000 RPM's right at 77mph.
HIVOLT is offline
Old 01-11-2020 | 02:14 PM
Do you have any eng upgrades or stock 496 Mag HO's
Bravo one drives
Prop shop said if I went with 28p I would still be in the wot ok range maybe around 4700 and possibly pick up 5 mph
thank you
Old 01-11-2020 | 02:29 PM
Stock HO's. 4700 will really not help you much as you should be running closer to 5000 for best performance. What are you turning for RPM's and speed now?
HIVOLT is offline
Old 01-11-2020 | 06:36 PM
Default Baja33
the best I've seen was 5000rpm and 70mph
